chevman723
I had changed the fuel filter and cleaned the screen in the inlet of the pump after this issue started. It didn't make a bit if difference. I'll try and crack the injector lines and let you know what I find.
And not affect the compression, and most of us would never think to check the valves.that will kill the power
Xpackdeals I ordered the adapter last night from autotoolworld.com. Item # Sg35300.I am unsure if it will fit my compression tester or not. I will have to get one that is compatible if it doesn't work with my gas engine one.
