Skid Steer Tires - what kind should I buy
Rob1325
Ct
I bought galaxy muddy buddy, they are very nice. Machine goes through practically anything.
JS750
Northern Ohio
Titan he on bobcat s750 lasted 550hrs. 25% dirt 75% pavement. Oem only lasted 200 hrs. Will buy he again. Michelin bibsteel lasted 350 hrs. Tire road excellent,but pricey. Recapped the bibsteel and put them on an 863 and are lasting very well. The heavier machines really tear up the cheap tires.
dave esterns
madison
the local tire guy says titans are good. i find the 10 inch bobcat brand tires to be decent for me on the farm.
durallymax
Wi
Just replaced a set of Bibsteels that had 3,000hrs on them. Sent the casings out to get recapped. Deep wide tread, should work well. Won't know for awhile though, have to wait for some tires to wear down.
durallymax
Wi
Were you running Bibsteel AT or HS?
JS750
Northern Ohio
Bibsteel all terrain. This will be the tire I will eventually go back to, but I am going to try the titan ultimate a/t with 44/32nds tread dept first.
durallymax
Wi
If you go back to the Bibsteel you may want to try the HS, I've only used the AT, but the HS is supposed to be better for pavement, sounds like it may work better or be worth a shot.
