Yair . . .
In some/most soil the detent can be used when production dozing in properly constructed slots . . . that is to say when the blade is fully loaded pushing a train of dirt in the slot you can slip the blade into float and the load will come off the tractor and it will often gain a bit of speed.
The caveat is that (as I have said on here before) very few operators know how to construct and work a proper slot.
Cheers.
Hi , the float position can also be used in the shop when a blade ( or a bucket - track loader ) has to be raised without starting the engine . Of course you need a lifting device .
Another thing : In the 70-ies there was a Cat instruction film about dozers and scrapers . Once the pusher had contacted the pushblock it was shown that the operator put the handle in float position to follow the vertical movements of that push block when the bowl is lifted or dropped .
Although I was involved in dozer and scraper work for some decades I never told the operators to do so . With the blade in float position the pusher will lose some weight and thus traction while the rear end of the scraper will be heavier .
Have a nice day , johan7
Impressive!!Wish I had taken more pics)
I agree that is top notch grading, but curious how did you or would you finish the topsoil for seed if you are trying to get a yard with minimal hand work that can be mowed with a lawn mower? Would you dress it up with the cat so there are no track marks and no berms that can't be kicked out with your toe or bring in another piece of equipment to drag it? Just saying there is more than one way to skin a cat.If you can grade that good forward,I would expect you can do it backwards, but it is not that easy to do it right. I will say that it anything bigger than a D 6 with a p a t blade is not good for doing that type of back blading so I don't bother.
Here is a pic for Dr Ernie.I was applying for a job and the owner was impressed enough to hire me I guess.Actually I was running that D8H in my avatar I think,maybe it was a D8N,not sure now but it is fun to be able to do the things that will impress other operators.It got me the job anyway.Ron GView attachment 144933
Yair . . .
Cheers.
Remember this thread, Scrub? ...For you Scrub! Will this work?
