christophercale
Hey All -
I posted this as a reply to an existing thread in the dozer section, but no replies so I thought I'd try here.
I'd like to ask for input regarding using a track loader to clear trees, versus a dozer or excavator. I'm in central Texas and my property, about 25 acres, is completely overrun with Huisache (Wee-Satch) trees. They have zero value and are a major nuisance, full of thorns and nasty to clear by hand. The majority of my trees are in the 2 to 6 inch diameter range, but there are a handful that are 10 inches or more. The tallest is about 20 feet. The average is probably 10 to 15 feet. They have to be ripped out by the roots or they re-grow. If you just cut them, you have to spray the cut stump with Remedy to kill the plant. The soil is black clay with a lot of flint rock anywhere from golf ball to softball size.
I've cleared about 5 acres with a JD farm tractor and a 3-point Turbo Saw, but man is that slow going. I also have a 3 point tree puller and I can pull most anything that is about 5 inches or less, but again, very slow going.
I've been doing a lot of research all over the net & forums. Until I got onto the Heavy Equipment forum, I did not know that some guys were using tracked loaders to clear trees, but it makes sense. I'm weighing having a contractor come do the work versus making an equipment purchase. I'm leaning towards purchase because I'm sure that I can always find other stuff to do with the equipment, like cleaning out an existing pond, making new pond, lift heavy stuff on the farm, etc...
For you guys who have experience clearing property similar to mine, what's your experience and advice specifically as it relates to track loaders? Can you get under the roots of a 10 inch diameter, 20 foot tall tree and uproot it?
Thanks -
Christopher
Thanks -
Christopher
