I have done the piston rings and bigend bearings and a good hone at 20K hours . It had been burning a gallon of engine oil a day for the last 500 hours .
The oil rings were bad so that was the problem . I got new needles and nozzles put on the injectors while I was at it . I was at it for 3 months on and off and I also had to do the rear diff . Put it going and it seemed smokey and said that will clear .100 hours of hard work later and no Improvement .It burned no oil .
Checked air filter ,boost pressure, wastegate and slackened injector pipes one at a time wit no clearing of smoke at 1700rpm stall . I have no extra or loss of power doing a full stall test and from operating . Timing sounds good . Rang injector man who had no answers but I have always found his work very good .
It is a deutz engine wit individual electronic controlled pumps and old type injectors just without a leak off line all bosch .
Any ideas ?
Any ideas ?
