Have an issue with arm in function being slow and not having any power. Have checked pressures at pilot control valve and it's right in the acceptable range so that tells me it's either an issue in the spool or cylinder. I am planning on checking pressures at the arm cylinder. Anyone know what the pressure is suppose to be at the arm cylinder? If I take apart the spool any tips on checking out or replacing it? Thanks.
