ippielb
From what I hear people say up to 13 gallons per hour on the 973. Hopefully I keep it down a lot from that. Lol fuels expensive.
I know a 973 is in the same price range used as a 963-953. I guess theres not a good market for them because of there size which is good for us little folk. your machine sure looks good............
Weak batteries are very hard on starters
haven't you got a load checker
The battery charger i do have has the tester on it, but it's only 12v, so i can only check one battery at a time. it says "good" but i don't know if i should believe it.
You will need to borrow or make a 4C-8195 Service Tool, otherwise known as a Click Box, to remove the Codes. See this thread ......... https://www.heavyequipmentforums.com/showthread.php?30348-D6R-series-2-fault-codes/page2How does a person remove these codes? I can see the codes when machine is not running.
