I am wanting to add a receiver mast to my motor grader and dozer. On the hoe it looks like the magnetic mounts are the answer. I will end up using one of the led machine receivers. I may try to keep this simple on the grader with just one receiver. I have been looking to upgrade to maybe a Spectra GL422 Dual Slope Grade Laser and trying the CR600 Receiver then adding a 360 deg receiver like the Leica LMR-360B with remote display.
It think on the grader a adjustable mast may be needed. Say I am grading a ditch. I set the moldboad up for the angle. I would need to adjust the mast to a vertical position. I would like to remove the mast when not in use. Has anybody build one? Would you care to share photos?
