cutting edge
You are referencing the breather caps on the filter heads?
fuel tank
what is the fpr valve? rail relief?
You could have a bad SCV on the fuel pump. pull the brown connector at the front of the high pressure pump and see if it starts. Dont let it run like this though,just try to start it.
