Adding Roll off service to my busines
FSERVICE
indiana
the guys around here are running tri axle (tandem with a air drop axle up front of the drives) kenworths, with cables. However I saw 2 new trucks that were automatics & hooks last week on the lot!!!
still learn'n
Kansas
Sorry if I'm hijacking but Cm1995 on your comment about landfills who maintains a landfill after they are closed or how do they have enough money to maintain them after they are closed? Jerry
In Alabama it's the owner that has to maintain them after they close and have a bond in place also.
straightexhaust
MD
Now Im hesitant to buy Mack or International which is disappointing. Im going to have to continue researching makes and models to find the most reliable setup.
Trashman
Texas
Garboligist
We run 5 rolloff trucks and 80 containers. I buy Mack with Allison automatics. We have considered the hook lift but never bought one because all of our containers are for cable hoist. I have had no problems with engines are transmissions.
straightexhaust
MD
What years are your trucks? Where do you get your containers from?
We bought most of our cans from Bakers Waste Equipment out of NC and Nulife Environmental out of SC. Both make good cans.
Trashman
Texas
Garboligist
The trucks are 09,07 06,02 and 01. All Mack's Granite's with Galbreath tilt frames. We get our containers from Rolloffs USA. Most of our containers are 30 CY's but we have been buying some low profile 20 CY's for small contractors and home owners. A 30 yarder will run you $5000. We make more money in the rolloff business than we do the residential solid waste collection business.
dirtcurt
minnesota
I have a small hauling business and do some dirt work, we added a hooklift truck to our fleet a couple of years ago and it was a great addition. I bought a used ampliroll hook (60k) on e-bay and mounted it on a quad axle 357 Pete. The guys at Marrel have been very supportive when I needed technical assistance.
I run 10-40 yard cans. Seems like the 20-30's are most used by my customers, as mentioned before the 40's get overloaded too easily and I tend to use them mostly for my own projects. One thing I did recently that comes in handy is got a 20yd that fits inside the 40, this saves a trip when going to the demo site and I use the 20 for scrap iron or something else that may need to be sorted.
I also have a flat bed for the hook lift that is very versitle.
Although my Pete has a 9ll trans I think an allison would be the way to go if you can. I have a couple tandem KW's with allisons and think it would be really nice in a hook truck.
This winters plan is to re-mount the hook on a bit newer KW chassis that we built from a wreck. I will post pics when and if we get this done.
Welcome to the Forums dirt curt!:drinkup
Ampliroll is a good hoist, we were happy with it.
Kchauler
Kansas
Just wondering what was the best way to grow your roll off business we have been in the equipment rental for 13 years and have 7 stores we also run a portable toilet business with over 700 portable toilets out we just got into the dumpsters this year with a hook lift and 20 20 yard containers it's going good we rental probably 7 to ten dumpsters a week mainly to residential clean outs and such but just wondering what would you suggest to make it really boom to where I have to order more containers
joispoi
Connecticut
I bet I can find you over 700 prospective customers in under 5 minutes.
Welcome to the Forums Kchauler!:drinkup
With 700 portable toilets I image you have a lot of contractor business? If so there's your client list. I would offer them a package deal as one of the first two items needed on a job site is a toilet and a dumpster.
Often a toilet is one of the first items delivered before the GC needs a can. Get in on the front and lock it up.
We were considering getting into the porto business pretty seriously, then the economy tanked in 2009. We were going to offer package deals as the client list overlaps.
Kchauler
Kansas
Oh believe me the toilet customers have already been hit up most our toilet customers Are home builders
Kchauler
Kansas
Who have a hard time spending the money on a toilet but do it because they are required on a new house build no the ones I'm trying to look for are the long term dumpster rentals the steady money what would you all
Suggest there
Kchauler
Kansas
I'm also wondering how many can do you guys think a guy should be able to exchange or set in a day I know distance is a big factor on the runs but on average do you all think 5 to 10 can a day per driver
Kchauler
Kansas
And sorry to be a forum hog but does anyone use a salesman to push the dumpsters and if so how does it work for you is there a return on that
Suggest there
The money is made in the quick swaps and return or out to another customer.
