John C. is spot on.
The weak spot wasn't necessarily the final drives. But they are now because of the age of the machine.
They are totally obsolete from Komatsu. To my knowledge I have the only solution in the world that works.
I have to take a current production final drive, change the manifold on it, change the gear ratio on it and then the expensive part...I have a custom sprocket made for it.
We've designed this replacement to be an exact interchage for the original. It is even the same brand as the original. Same performance, same hydraulic connections. It shows up, you install it and go. No worries about retro fitting anything, we do that for you.
The Hy-Dash series used in this machine was obsoleted almost 10 years ago and there are no complete units or replacements offered. Even the parts are gone. The center bearing in the RV assembly in the gearbox is what wears out first and I bought the last one in existence in 2008. Paid dearly for it too.
No parts = no rebuliding.
Doesn't sound too bad yet, since I do have a solution. Here's where it gets bad, the cost.
For what we have to do to create a solution for this machine it costs me A LOT of money. We sell this unit for almost $8k and make less than 20% profit.
I continue to build them and have them ready to ship because we do sell 2 or 3 a year. But the cost usually approaches that threshold of whether it cost effective to invest into this old of a machine.
Aside from the finals, any other parts are available. Used parts, apart from finals, aren't too difficult to locate.
I would check the final drives very carefully. Drain the oil, see if there is any metal or if it has a silver color anywhere in it. 11,000 hours is a lot to get out of any bearing in any excavator final drive. Remember, the center bearing is not available anywhere.
I always recommend having an oil analysis done on engine, hydraulic and gear oil. That will tell you the health of the machine.
