some work pictures
RBMcCloskey
New Jersey
Heavy Construction Contractor
God Bless you Tom, another occupant of "God's Garage", great in the summer...not so much in the winter.
still learn'n
Kansas
TOM V
CONNECTICUT
Mechanic, Welder, Office work ect.
Jerry, I use Hougen modified 12000 series M42 TiN coated cutters and have drilled [9] 7/8" holes in HARDOX 400 and still have the cutter in use. There are also rail road rail cutters available from TRAK-STAR that cut up to 400 Brinell.
RayF
Perth Western australia
lineborer/welder
How did the centre equaliser bar pin go Tom? They can be a pig to get out. Will the outer bores take a bearing or is it a machining job?
jjimbo
so cal
Field mechanic/ owner operator
Hey Tom that crane you got makes me kind of drool lipped. But I am sure that at times you wish it was bigger.
TOM V
CONNECTICUT
Ray, the center pin came out easy but the outer bores do need machining.
nicky 68a
england
lovely clean little tractor.I have just put new ends on my D5H eq bar for the second time in 14000 hrs.
TOM V
CONNECTICUT
Tom,good morning from Canadian west coast. When you installed the new Blue,did it take up much more space?
It is 4" taller, 4" wider, and 5" longer. The machine fits well on a 36" welder deck.
jjimbo
so cal
Tom what size of puller rod are you using? I may have something you may like.
