Jd plbg
I was hoping you all could help. I have a bobcat 331 that gets stuck at the same spot when rotating the cab. At roughly 20 degrees it will stop and I will rotate it back the other direction for a full 360 degrees and it will stop in the same spot. Any ideas on where I should begin? Thank you
