Shimmy1
When I worked for a small contractor we did a lot of hourly work. He would charge for mobilization for each machine,and we would charge for the most expensive machine on job all day. So if they wanted an excavator on site (I think he charged 150hr) but I only ran it 2 hours, and ran a backhoe (I think 80hr) the rest of day we charged for the excavator all day.
This is an interesting approach. I, too, struggle sometimes how to charge. But, I'm not sure my customers would approve of me charging them 12 hrs for the hoe if I only ran it 3 and was in the loader the rest of the day.
Well if you're the only man on the job it is hard to say that both pieces are working at the same time. If you're loading a truck and jumping back in it to go dump then I would say you could justify charging for that truck all day, but if you're dumping 5 miles away the hoe/loaders hr meter should be off until you return. If the dump site is on site that's different. Charging by the load could solve this problem. As far as the rental thing, that's a tough spot. A lot of times if it is a scenario where we are doing a large site we charge by the ton or yard. exp - $1 a ton to compact.
This always seems to be a judgement call for me. If I'm hauling dirt out of a borrow site for fill, then I charge a per yard loading fee, usually $.50 to $.75 per yard. The truck, if onsite, is hourly for the whole time, if it's going offsite, then I have a price schedule depending on mileage. If I'm cutting grade for a building or grain bin site, the truck basically stays the same, but I charge the hourly rate on the hoe. How I arrive at that number is I will time a few loads with truck and take the average times how many loads and subtract that from total time with hoe. I have never been a fan of using the hour meter for hours because I will not shut the engine off as soon as bucket hits the ground. If I'm gone less than five minutes, I'll just let the machine idle. Over five, I'll turn on the auto stop and let it do its thing. Interestingly enough, your figure for compaction is pretty close to me. $1.50/yd³ for level and grade, $1.50/per for compaction.
