micmut
Dial gauge bracket
Dholm Don't give up there is a solution !
I made up a bracket to hold my dial gauge and found it to be out .055 in. So I ordered a new motor mount finding that there is a newer one then the original. The dealer had sent me 85mm grade 5 bolts, where the new mount calls for 100mm, and i will find grade 8.
The face of the block is in rough shape so I intent to grind it to get a better runout. where the bushings may fit louse, here i'm not sure, should i glue it when i am satisfied it is true. There may not be enoff room for changing the belt after this? I do cringe of the use of jb as well. Now If any one has a good idea im open ears!!!!!!!!
Would some kind of epoxy be good to fill the voids? Pulling the block is not realy wanted, rebuilding or replacing the motor is not in the budget.
