I have a Gradall 534B which has a typical Delco Remy charging system (internally regulated) identical to a million old GM cars. I have been having a discharge problem with the machine for some time now and have been unable to get to the bottom of it. When I disconnect the sensing wire from the alternator, the discharge disappears, reconnect and there it is again. I tried disconnecting the sensing wire and running another around it to eliminate it as the problem, but no luck, the discharge was still there. I had the alternator tested and it's fine. I replaced the alternator with new just in case and that made no difference. What the heck am I missing? Incidentally, in getting to this point, I had disconnected virtually every wire in the machine with no change until I unplugged the alternator. I've reached the end of my capabilities and figure that one of you guys may be able to set me straight.
