I've got a 1996 1845C with a leaking right side drive motor. I bought the Case rebuild kit with all of the seals. I pulled the drive motor last weekend and replaced all of the seals on it. The motor was in great shape with no obvious issues. The casing is all in good shape and has no cracks or severe signs of wear. After re installing it the motor worked as it should, except it is still leaking in the exact same spot!!:Banghead There are 3 separate pieces to the motor. It is leaking between the last two pieces. (The joint closest to the center of the machine) The oil is dripping out at the same rate as before. The casing does not fit tight together and didn't before. The left side drive motor fits together the same way so I'm assuming that is the design? Should I disassemble again and install some sort of sealant between the joints? Any help or advice would be greatly appreciated. I can't see spending $1700 on a new drive motor when the one I have works great, but only leaks. Thanks.
