.RC.
Thought some of you might like to see the process I went through to make a quick hitch for my old 922B loader.
It is made mostly out of flat bar, the two pins to knock out to change attachments are hollow and I turned up a long pin that you put in the hole to hammer the pin out so you can hammer the pin in and out fromt he same side, it is retained by a long piece of threaded rod with a square washer both ends...
