Hello all, new member here and hoping for a little advice. I recently purchased a Komatsu D65E-6 dozer and I want to change the oil in the final drives before I put it to work. I've operated Cat dozers in the past but have no experience with Komatsu. Is the Komatsu a wet brake setup and if so can I run Cat fdao or regular 50w ? I was checking out oils produced by Shell and came across this bit of info • Compatibility - Shell Spirax S5 CFD M 60 is fully compatible with all seal material employed in CAT equipment; and is also compatible with Shell Spirax S4 CX oils and oils meeting CAT TO-4. Shell Spirax S5 CFD M 60 should not be used in transmissions also containing friction materials (eg those with wet brakes or clutch materials). Use of Spirax S4 CX oils in those transmissions is recommended. Any recommendations would be appreciated.
