JHESL
We're chasing an annoying problem on my 450CLC. It tends to work fine in the morning with full power to all hydraulic functions. However, it will sometimes without warning lose hydraulic power and all functions, including crawling, and will slow down as if somehow the hydraulic or pilot system is going into some sort of slow mode. We've cleaned the pickup strainer and changed all the filters and tighten the clamps on the oil intake pipe, etc.
The engine doesn't load up or slow down. It's just the hydraulic functions slowing down. Please note that this machine has a "2 in 1" pump and it appears that both pumps are affected, so I'm thinking it can't be a regulator problem, as it has one regulator for each pump?
We're now down to thinking it must be a pilot system malfunction or something to do with the ECM?
I would appreciate any ideas anyone may have on what this could be.
