On the bleed thing, with the throttle in the shut off position and a fuel tank more full than empty, all you need do is loosen the fuel lines at the injectors, you dont need to spin the engine, the fuel filter will need bleeding on the hand valve first, there is bleed valves behind the fuel pumps but I never realy bother with them, it can take a few min's for the fuel to passage through but it will as long as the throttle control is in the stop position, it will then start and run very quickly without to much mess.
tctractors
