Michigan 175B?
xxspencexx
west australia
Hi, is this a 175B? It has a a Detroit in it if that helps. I think it's a B but I'm not sure.
loggers son
bathurst australia
shovel logger operator
umm it looks as though it has clark diffs, but everything else is wrong when compared to what comes up on google images for clark michigan 175b.
it does look a little like a furikawa unit i ran for a couple of weeks a long long time ago
ben46a
Waverley NS/Fort Mac AB
Looks like a 175 to me. Boom looks a bit different from the ones I've seen, but not sure if that's a difference between the 175 "a" and "b" models or not.
renaud
quebec canada
The cab on this one means nothing at all.....it is obviously home made.
I saw some 125B with "small" boom like this one.
If it is a V6 Detroit, it is a 125; if the Detroit engine is a V8, it is a 175.
nice machine though.
Max.
norite
Sudbury, Ontario, Canada
I'm no expert, never owned one of these but I have seen a few around. Please correct me if I am wrong.
175 The original straight frame design, with behind the cab boom arms that came down alongside the operator, if he stuck his arm out they could hurt you.
175a A more modern looking straight frame machine with boom arms that are hinged ahead of the cab.
175b An articulated frame design, early rops had long back braces going down to the frame near the rear.
175c Modern design, got the rops inside the cab, cab still has a square, box like structure, vertical windshield.
In my opinion, the op's picture looks like a 175b to me.
oldseabee
Milner, Ga.
Retired
Check the Serial numbers. Starting with 427A through 427D are 175B Detroit engine. 438C through 438D Cummins.
491A and after are 175C Detroit engine 490A and after are Cummins.
S/N is stamped on both frames and in the hinge area.
Rolitto
Planet Earth!
The machine in the picture is either a Michigan 125IIIA or 175IIIA as both models are identical but featured different internal parts.
renaud
quebec canada
Would you, by any chance , have the same information regarding the 275B and C's??Wich serial numbers had the Cummins and wich ones(if any.....) had the Detroit....
Thanks.
Max.
Rolitto
Planet Earth!
Clark 275B
The Clark 275B parts' manual has the followings written on it:
N0. 3070
Model 275B
Articulated Tractor Shovel
Information contained herein pertains to Machine Serial Numbers listed below:
275B Cummins - 425C101 and After
275B Cummins - 425C101ENC and After
275B Cummins - 425C101FSC and After
I hope that helps.
oldseabee
Milner, Ga.
Retired
The 275B had Cummins NT 855 c 360 or NT 855 C S/Ns 425 A,B 425C A and after had NT855 C 380.
479A101 and after Change to Cummins KT 1150.
482A101 and after had GM 8V92.
I suspect that by now a lot have been repowered.
S/N 425B 101 and after had a C8502-17 convertor previous to that had C8602-20
482A 101 and after had C8602-47 convertor. If you are going to build a convertor, be sure to get the right parts manual
Ryan151
Colorado
its not a B model it looks like a 175 with a rops and cab option to me. the B model has the z bars inside of the double plate boom arms. as you see in the pics rolitto posted.
