I think your company wants to give somebody a paycheck to do it wrong. If you want somebody else to get that paycheck then by all means try to prove it to them that they're doing it all wrong. Seriously, you can't win on this.
Don't tell anybody, but you can sharpen your edge on a length of asphalt road. Just lay your edge down carefully, and sharpen it over a distance.
Some sparks will flow as u go, but the edge will then be good to go.
I see the problem doing this with the 24 though...
Yup this works good, but just be careful of the grass in the ditches. I've heard of a few guys starting ditch fires from the flying sparks.( I will NEVER admit to starting any ditch fires myself, but have seen it within minutes of me driving by. Must have been the other guy! lol)
Maybe this diagram might help. It's basically the same as the one I posted before and expanding on posts that various contributors have made to date. Consider the "sharpen, cut, & roll the material" to be a 3-step process that goes something like this. That's what the 3 parts of the diagram are intended to show if you read them left to right. The thick black line represent the road surface.
Step 1 - Roll the moldboard back and use the road surface to "sharpen" the bottom of the cutting edge if it's not already sharp. Note how the edge is parallel to the road surface. Think of the road surface as a sharpening stone if you like.
Step 2 - Once you have your cutting edge to the desired "sharpness", roll it over forwards so that only the front corner (toe) is touching and the heel is well up above the road. Think of it as a chisel if you like. This is going to give you the most downwards cutting pressure on the road surface that the deadweight of the grader will support. Any more than that and you'll simply lift the front wheels in the air.
Step 3 - As soon as you have penetration and the material is "rolling" up the blade nicely then the moldboard is rolled back slightly to decrease the angle of attack of the toe (and so prevent the cutting edge trying to continually dig itself into the road) but at the same time not so far as to allow the heel to touch the surface and thus lower the downwards pressure on the moldboard. The happy medium is somewhere in between. However while you are grading if you can actually roll the moldboard well back you will in actual fact be sharpening it ready for the next cut.
Note: Whether you use either straight or curved cutting edges a brand new set are going to have a certain amount of "inherent sharpness" because of the way the edges bolt to the moldboard and the angle at which they present themselves to the road. The trick is maintaining that sharpness right from new to worn out.
P.S. For obvious reasons the thicker the cutting edges the more difficult they will be to sharpen.
