wow, amazing feedback
for you hitch you can knock up a "half" hitch
only leaves 1 pin to hit in and out and makes the first pin even easier to connect buckets are reversible because you just swap the fixed pin
http://www.eiengineering.com.au/assets/Uploads/1.8TonneHalfHitch2A250.jpg
something along these lines
I feel a bit stupid, but since I only have 1 bucket I have never had to change buckets on my mini ex. Thus I always presumed it was the most basic 2 pin affair.
However at closer inspection I have a pretty cool quick hitch system.. I just saved lots of money by just going outside.. nice
The chart looks to have good info but I have no idea what it is saying, it's in what language?
its in german, which I cannot speak aswell. Apparently only the VE columns apply to my HR12, so I translated the whole thing to english and only left the applicable columns.
For a hay bale I think its safe to add 1.2 meters (length of the round bale I'm using) to the actual dipper position. So only the horizontal 2.5m and 3m columns would apply here as the 1.3m and 1.8m columns. This means I can stack the round hay bales 2 bales high and cannot reach deeper than 1 bale.
Can you turn your bucket around 180º?
Nope, I have been thinking about just making an adapter plate that would enable me to turn around any attachment. But thats way bottom of my todolist, its like #1246 on my list (yes, that is the actual number).
Couldn't you just weld some sort of adapter, like a receiver hitch from a truck, onto the back of your bucket and have the hay spear connect to that?
I would probably fab something quick off the bucket first to see if that machine can handle a bale even.
This time I even didn't have to go outside to save money, good thing I keep pics of my scraps in my laptop:
Since this is the front axle from a truck, the bearings should easily handle a 300kg bale?
Maybe just drilling some holes in the little bucket and bolting the axle via the 4 wheel bolts directly to the bucket is enough? Would it just tear the bucket?
It is kinda inconvenient to change from digging mode to hay mode, but this solution would literally cost me nothing
How about adding a thumb, would it be large enough? I've seen bales moved that way before, granted with a bit larger machine.
Thumb is what I was thinking too. But looking at the pic of the mini-ex that he posted, I'm not sure if he'd be able to grab enough of the bale with a thumb?? It may just tear a piece of the bale out.
Andrew is right, the bucket is just so small it would tear a chuck off the bale or just mess it up so much it becomes unstackable. However I will be using the thumb to tear up the bale for loading into feeders.
