Wombat HT 50 Skid Steer - Chinese Bobcat!
d4dozer
Perth Western Australia
Hello
I have a HT 50 Wombat Skid Steer which displays an interesting habit of randomly "clicking" when attempting to start. The click is like it has a flat battery, but if you "click the starter key" it eventually turns over with no problem. It may take anything from 1 to 4 attempts.
I replaced the main relay, the smaller relay behind the starter switch, the starter motor and solenoid and obviously the battery.
I have heard of another Chinese machine (not a skid steer) displaying a similar quirk.
It is by no means a major problem, just a small quirk that I can live with, however I am intrigued to find out if anybody else has come across the same thing?
cheers
stondad
Queensland Australia
Truck Driver
Did you find the main isolator on the loader?
Maybe the Wombat has one too and that is where our cause is common to your two and my one machine.
It will quietly click once when you turn the key from off to on and viceversa.
Just a little joke I forgot yesterday about the Wombat loader. (The brand name is "Junlion").
The knob for the engine stop is labelled "Extinction Button"!
Cheers. M.
d4dozer
The loader does not appear to have a main isolator, thought the Wombat does. The Wombat has a grey handle which completely cuts all power from the battery.
My humour - the Wobat has a sticker which says, Caution CRASH engine before ........
d4dozer
Went past the Wombat dealer today and he said that if the solenoid/relay is defect defective it would never start, so he suggested I replace the ignition key
Lee (MN)
Minnesota
HE Mechanic
Very interesting, I have never seen one before, looks very much like a Case machine.
Lee;)
Greg
Wi
Excavating Contractor
Lee, you are right except you forgot to put in "very very old" in front of the Case.
As usual the chinese probably bought one here that was wore out and took it back to copy it.
d4dozer
Just like the Japanese did in the 60's and 70's with a lot of stuff. The problem is that when they are $27K including GST and the others are $50-80k, its hard to justify paying the extra cash. But with that comes little problems.
Greg
Wi
Sounds good when you say it fast d4dozer. That version of a Case skidsteer goes back to probably the 1970's. They had an air cooled small four cylinder gasoline engine, drive train that left everything to be desired, had no power, no push, no response inthe hydraulics. They were a very crude machine and not very productive. That early design was mainly for agricultura applications, mainly for farmers to clean up sh** out of cattle barns where they could not get in with a tractor with a loader on it. But look where it was built. That is about that they are capable of in china only there they would use 450 people with forks, shovels and wheelbarrows.
d4dozer
I am not an advocate of Chinese machines - I understand how nice some of these modern machines are, I drove a Mustang, they wanted 35K for it - an old heap of ...... It needed money spent on it and I needed a machine for weekend use only. The wombat has as much power as the Mustang, a four cylinder water cooled motor, with hydraulics to drive a post hole digger, three way bucket and a few other attachments. By no means a top of the class machine, but in the 6 years I have had it, I have been served well, had I bought the Mustang I would have spent a CASE of money on it by now. My machine has 325 hours on it since new - will it get to 10,000 hours, probably not, will it see out my time on this planet, it probably will.
So I will say it again, not fast, but slowly, when a machine costs $27K and does what you want, a second hand (non Chinese) machine with 10,000 hours cost more than a new Chinese machine, why would I pay $50 - 80K for something else. If the machine was working every day and my lively hood depended upon then sure, do the maths! Would I like a new western machine, sure, but bang for my buck, this has been good value, maths is simple. Yes some annoying traits, but it does everything a non Chinese bobcat will do.
JDOFMEMI
SoCal
It sounds to me like you are getting low voltage to the starter solenoid. I have had the same problem on pick ups, notably Toyotas. The low voltage will not energize the magnet enough to make a solid connection inside the solenoid. This leads to a burnt spot, and then each time it seems to get worse. One usual suspect is a bad ground cable, or the ground cable not being in close contact to the starter. You may try adding a new ground direct from the starter to the battery, or the isolater switch. If that does not work, check the wires on the positive side, both the main power to the starter motor, but more than likely the wire from the switch to the solenoid.
Your little machine seems to serve you well, and that is what counts. We can't all have the latest and greatest machines.
d4dozer
Jerry - Thanks for that - food for thought - I will check it out. What is interesting is that the battery, which has been replaced at least twice in its life, has a heap of blue & white crystal's forming around one of the battery leads (copper sulphate?) The amount produced is subdtantial, perhaps a "blob" 50 mmm (2 inches) in diameter. I wonder if that means anything - I used the same brand of batteries in my other machine but it has only formed on the bobcat.
I assumed it was a result of the dissimilar metals used on the battery clamp.
JDOFMEMI
SoCal
You may have the right thought about what caused the crystals, but they might have "migrated" down the inside of the battery cables, causing a loss of contact inside of a cable that looks fine on the outside.
I have had that very thing strand me in the desert before, and now keep a sharp eye out for it.
JDOFMEMI
SoCal
In my experience, once it starts, it will go all the way to a low spot, then sit and eat on the wires.
Short of stripping the cable, it is hard to find.
LT-x7
Central COMMI-fornia
Earth Moving Contractor
I also have had this problem on Japanese cars and trucks. After replacing all the usual suspects like you did I found a solution that worked. I added a relay to the ignition circuit close to the starter. I used the stock ignition wire coming from the key switch to the starter solenoid to switch the new relay I added. Then just 12ga wire directly from the battery side of the starter to power the relay, then another 12ga wire from the switched side of the relay to the starter solenoid. Bingo never clicked again!
LT-x7
LT-x7 - your post also suggests not enough power making it to the starter? I wonder why it is an intermittent problem then?
It was not enough power going to the starter solenoid, plenty of power at the starter motor itself.
This was in a motor swapped car, before I fixed the problem I replaced the the starter, battery cables, ignition switch, and added extra grounds. No clue why its intermittent.
