Hi there, i have a d6c 1971 and i am looking for some good used tracks + pads. Does enywone knew what kind of chain it is on my machine and if it`s the same chain on somewone else dozer that wil fit on a d6c? I`s there a standard model?
That must be a later chain as my Cat literature shows the 8.00 in. pitch chain for Komatsu and the D6C as using the same sealed track link assy 3P1088 part number.
My 1989 Caterpillar Parts Sales Kit Form PEKP9100 shows a whole list of D6C track shoes that fit the 3P1088 link assemblies (same as Kamatsu D60 & D65 with 8" pitch) using the same 3P1112 RH link and 3P1113 LH regular links......What gives????
There is a fine print note that Cat and Komatsu shoe bolt hole patterns are not interchangeable. Does that mean even though the link and assembly part numbers are the same, they are actually drilled different?
Even if the pad bolting were different, would they not interchange as a complete pad and chain assembly?
