Driving tracked C238 backwards for long periods of time
droter
USA
Hi,
Does anyone know if it is a problem to drive a C238 tracked skid steer backwards continuously for 8 - 12 hours a day?
Thanks,
Matt
KSSS
excavation
I believe they prefer going forward like all tracked machines, but i couldnt explain why. What application are you in that demands going in reverse all day?
Bobcatdan
wisconsin
I don't see a problem. Hydros and drive motors are designed to run either way no problem. Depending the under carriage may wear weird a bit running backwards, but I wouldn't think anything real not noticeable.
droter
USA
Thanks for your answers.
Kind of a weird application but we need to use one to pull an implement instead of pushing.
Matt
Karl Robbers
The answer that comes to mind here is that your undercarriage will suffer.
When running forward, the surface of the track on the ground is pulled tight by the drive sprocket and the only slack is in the return side. Running long periods in reverse can lead to slack between the drive sprocket and the track rollers,leading to premature wear of your sprocket and undercarriage. You may alleviate this to some degree by running your tracks tighter but this will chase the stresses and wear elsewhere.
durallymax
Wi
The hydro system will be fine but as mentioned above the tracks are made to push in one direction. Now if you are doing something with low draft loads such as trenching then its not going to be as big of an issue, but if you are trying to pull something hard through the ground maybe look at pushing it?
I think your nexk will wear out before the machine though
droter
USA
We will be pulling a wheeled 400 gallon sprayer. Once the tank is moving there won't be too much draft.
