Kalashnikov
The water pump pulley sheared off 3 bolts and tore up 3 of the 4 mounting holes the other day. Water pump spins fine and alternator spins fine. I had just adjusted the belt a couple hours before this happened after having the alternator loosen up and having the belt come off. I have not been able to find another pulley. It's got the V1702 Kubota in it and is an early style machine from the late 80s or early 90s I believe. 3600hrs approximately. I'd rather get a new pulley before fixing the old one so I don't have to worry about having it out of round and bent chewing up belt or pumps.
