black60church
i have a td7g dresser with cummings motor, dozer works perfect, when i bought the dozer the trans pressure gauge didnt work, it was broke, so some one plugged it off, i put a new gauge, and the pressure is around 290, but when you put it in neuteral the pressure drops to zero no matter what the rpms are, then when you put it in gear the pressure goes to 290, trans works perfect in all gears hot or cold, is that normal, i would think that it should have pressure all the time, CAN ANYONE HELP, THANKS
