bowen
Not sure if anyone can help with this or not...
This is a question about a Case 470 Tractor. (Gas)
I have it partially restored for use so it's not a show tractor.
The problem involves a pressurized gas tank.
While bush-hogging I often smell gas. It is hot in the pasture and the grass is thick so the engine is working hard, but no problem with the water temp.
Every time I added gas I noticed that air would BLOW out the fuel cap when I opened it.
This is a new cap supposed to be for this tractor. It has a cork gasket but I do not know if it's vented correctly or not.
While mowing I started screwing the cap off every 3 minutes and every time it would blow out pressure.
After I shut it off yesterday I loosened the cap and that thing was practically blowing out air as if the gas was boiling inside.
It was just a constant flow of hot air. Continued for 3 or 4 minutes..
This fuel tank sits right behind the engine/tail pipe, so it HAS to get hot.
It seems to run fine with the pressure in the tank:beatsme
Should I run it under pressure or try to remove that cork gasket?
