thahn1608
I have a Ford 550 TLB that I've done a lot of work to, but have a recent problem I can't figure out.
The machine starts fine first thing in the morning when the engine is cold regardless of the outside temperature.
The problem arises when I shut the unit down and try to restart it. When the engine is warm it will not start for anything! I have to use starting fluid to get it to start and sometimes I have to keep it running on starting fluid and get the rpms revved up then it takes off like a rocket with the throttle wide open. Here's what I've checked:
The engine gets plenty of fuel and the injector pump works just fine. The injectors appear to be working fine - once running it has plenty of power, doesn't smoke, and at top rpm's it doesn't shutter at all. The motor was completely rebuilt about 250 hours ago. There is plenty of oil and pressure. The cylinders all have really good compression. And lastly the air intake is just fine.
The problem has me baffled. I was thinking a sticking valve, or an injector that is clogged, but nothing seems to fit other criteria for them having issues. Any help is always appreciated!
