johan7
In 1967 I had to do with the 657 scrapers of the first series . These were equipped with a semi automatic transmission . You had to shift 3 speeds and every speed had 3 more speeds , in total 9 speeds . Downshifting was ONLY ALLOWED when the indicator was in DOWNSHIFT . One day a loaded 657 entered at full speed the fill area and started bouncing while the operator used the shiftlever as an armrest . He put the lever from third (=9) into first . At that moment the two exhausts gave some fire and it was all over . result : engines overspeeded .
My photo shows the machine at the place where it came to a stop . The 2 engines had to be removed and after a week it was running again . The cable in the front is from a dragkine that is going to lift out the engines .
Am I the only one on this planet to have seen it ? Come on with your stories !!
The Netherlands , johan7 .
