I work at a U.S. Equipment Attachment Manufacturer that will remain nameless as Forums do not and should not be commercials. For Land Clearing applications as in most cases the right tool for the job makes your day a lot easier.
To the point; we see the trend for land clearing with Excavators to certainly equip the machine with a coupler. The icing on the cake is to also equip the machine with a Thumb. The Thumb should be designed to stay on the machine when you uncouple (We are careful not to say “drop”) an attachment. The coupler then allows you to swap from the bucket for digging out a rock or stump to then change to the rake for sorting debris from the soil for loading trucks or grinders. The Combination of the Thumb and the Rake actually provides a “grapple” type attachment for in most cases less $$ than buying a grapple.
We see in the States a real variation in regions and their preferences on the types of thumbs and if contractors even use thumbs. Any type of thumb is better than no thumb and it is almost humorous to watch operators do a balancing act with their machine to load material with no thumb when they could have loaded the same in seconds if they could get a grip on their material. If the bulk of your work is above ground and involves material other than dirt consider the Bucket, Coupler, Thumb, Rake combination. No the arrangement is not cheap but neither is your time and fuel.
Hint, Buy your combination attachment package from the same manufacturer so all products fit each other and there is one source of responsibility if there is any issues.
Have a great day all and try not to break anything.
