Well we see it has a angle hyd blade, hand clutch, elect start for the pony, the 4R s/n and the 5R s/n 1941-1947 and the 8u s/n and 9u s/n 1947-1959. Track gauge 60" or 74" and a draw bar HP of 55-75. We can't see the stack so water in the cylinders is possible which could mean some big issues. It's cheap enough but could need a lot of work, also if you have never run a dozer of this age or started one like this it is a job to say the least. I would like it for a show and tell but not to run all day for sure. I had run a lot of them in my teens. The other issue is loading and hauling from where it's at, will the owner let you work on it there for a short time. The weight will be around 20,000 pounds. After baring the engine over with the valves off if it turns you may be able to push start it, you will need to check the fluids, the steering pump res is a must along with the clutch release, if it starts the wrong way while push starting, it will spit the oil out the air cleaner on you. You should also get a shop manual, the injection pump, pony, clutch, finals, trans all need fluid checks before moving. It's like said a nice find if with a little tlc it would run!.
