tree_man150
- Joined
- Nov 21, 2012
- Messages
- 23
- Location
- custer washington
- Occupation
- tree service owner--i trim and remove trees
i dropped the oil out of my loader--took out the screen-- and discovered----oil looked to be only hydraulic oil, no atf at all- and enough metal shavings to warrant some conserns.
i cleaned out the screen-tried sticking a magnet in the sump, but got nothing--i'll say that there was about a nickels worth of shavings in the pan i dropped the oil in--that would be a nickel all ground up
question is--should i put hydrauic oil back in or atf
and if the machine was yours would you drop the trans and open it up for inspection/repair?
pics are just what was in the screen--pic of shavings in pan did not turn out
thanks for any in-put
