Funkyfullwidth
I got an air leak under the cab of the truck, a 1999 peterbilt 379 tractor only in high gear. The leak is on the side of the high/low selector behind the air line. there's a hole on of the castings and the other case half has a tang that covers it. The hole does not go anywhere, but the air leak is around that area. We had the selector apart and could not find any obvious signs of air leaking. The o-rings and gaskets all looked good. Which lead me to beleive that a sealed internal component is leaking into the chamber causing it to leak out of the assembly. Anyone ever run into this? Peterbilt want 427$... so looking for advice, thanks!
