Need advise on building a grubber for a D6
Gearhead75
Eldorado Tx
I have a D6D dozer and I was interested in building a tree grubber for the blade, I was wondering if anyone had ever built one and if so what would there recomendations be for thickness of material, design, depth to hang down below blade, width of cutting edge. Any info would be appreciated, thanks.
pp13bnos
Oregon
If you're like me, you'll build it "Heavy Duty" the first time. Realize in about 20 minutes of working, that "Heavy Duty" isn't nearly so heavy duty as you thought, then rebuild it at least twice as strong as the first time. :)
td25c
indiana
Almost sounds like your talking about a stump plow Gearhead75.Found a picture of one on wag-ways site,its for an excavator but people used to mount them on the front of the dozer blade . www.wagway.com/img/stump-plow.png Might even look for a Rome K/G blade for the D6D Cat,We have one and love it for clearing.
Rusted
Yair . . . Gearhead75. Over here in Australia I am unfamiliar with "grubbers".
Could you explain just what it is and how they are used?
Thanks and Cheers.
Scrub Puller I think he's referring to what we would call a cutterbar rake in Oz?:beatsme
Gearhead75
Eldorado Tx
td25c, I looked at the Rome K/G website and that's not exactly what i'm thinking about, this grubber would fit on my existing blade. I would weld ears up at the top of the blade with holes in them to allow the grubber to swing forward if you were wanting to backdrag. What i had in mind was 1in to 1 1/4 plate cut about 10 to 12 inches wide by 5 to 5 1/2 feet long and a piece of the same plate 20 to 24in wide welded to the two vertical bars flat ways and parallel to the ground with a bevel cut to make a cutting edge. this cutting edge would hang down 16in or so below the bottom of the blade, so when you go grub a tree you are only sinking the grubber into the ground instead of the whole blade, when tree and root ball are pushed away you can then backdrag in reverse and the grubber flips forward and the dozer blade is now flush with ground and you can semi fill the existing hole. MAYBE??
LonestarCobra
WV
Thats about how mine is. I used 1.5" thick steel and they were 10" wide. I put them 30" apart and the blade at 15 degrees when it hit the ground. It will go in 20" deep, enough to get any Mesquite root ball. I also added a push bar at the top that is just a piece of 4" 16.60 pound drill pipe. It sticks out about 30" and helps the tree over before the cutter hits it.
JoeinTX
Arlington, TX
Grubber
Hi, Buddy, some pics please
http://brownebrosinc.com/images/Range-Management-Tools/DozerTools/Thumbs/tn_Dozer-Grubber.JPG
Check link for pic. The "grubber" is used to dig out the root systems, primarily, of the mesquite trees. It's a tool to used against from small sprouts to large trees. The process is to grub the trees/roots out with the grubber and follow along behind with rake to rake and pile them for burning.
The "grubber" may be largely a Texas/Oklahoma thing. I've spoken to people in other parts of the country and most have never heard of it.
Scrub Puller
Yair . . . JoeinTX. Gotcha mate. Now I understand the concept.
What I don't understand is why this would be as effective as a conventional cutter bar between the ripper tines or a centre tine fitted with wings. I have used both and the advantage is that you can use them on a tractor fitted with a rake.
Putting wings on a centre tine is very inexpensive if you can get hold of some heavy worn out cutting edge.
Cheers.
LonestarCobra
WV
Here are some pics of the one I built for my 22x D5B. It is a smaller version of the one on my D6 and does not have the push bar on it. It is a regional deal where there is Mesquite trees. Since Mesquites have tap roots that go down almost as deep as the tree is tall, the object is to cut it below the root ball and pull it out of the ground. By doing this it helps minimize regrowth. The blade is hidden in the grass, but is the same material as the rest of it with a beveled edge and is sitting at 15 degrees.
JoeinTX
Arlington, TX
Cheers.
I hope I make sense here. The Mesquite is an extremely pervasive and resilient species of plant. It can be a tree.....or a bush......or a sprout. And in every variation it is an extraordinarily abundant pest. The only way to kill it is to kill at the root or to spend great time and effort applying chemical control. They will take a pasture over in no time if you're paying no time to controlling them.
You don't just go into a field of Mesquites and knock them all down with a dozer blade and be done with them. No. Do that and 5 years later that same pasture will be overrun with them again. You take each tree or shrub or sprout out at the deepest root level possible. That's what a grubber does. You nail each growth type deep and hard and with extreme prejudice. You do your damnedest to dig them out of the Earth itself.
It's not like root raking........it's not like root plowing......it's not like chaining. It's altogether and entirely a different way of brush control.
JoeinTX
Arlington, TX
And, to note, the very Mesquite that the grubber was designed to work against is the same tree that Lonestar's grubber is chained to above. Damned tough tree and tremendous in the making of early America. The mesquite is an African sourced tree that boomed in the post-cattle drive days. Cattle movement is what drove it's introduction into so many parts of the American Southwest. The Mesquite produces beans which are good cattle feed but which also are great for transporting the seed and species.
Gearhead75
Eldorado Tx
Thanks to everyone who replied, I never really thought bout putting a cutting edge on center ripper, does anyone know if this would work on mesquites very well?
