We has a rather long waterline to our building, and the water tastes like ****. It is standing to long in the pipes before it gets out. The construction company also made the cold pipes run to close to the hot water lines, so thats also a reason for the bad water. You got to have the taps running for 5 min before it gets drinkable.:Banghead
Luckily we bought a waterdispenser with CO2 dispenser, filters and a cooling unit. We connected it to the pipe and now the water is drinkable.
I use to mix a part of sprinkling with cold water.
I am not so fond of water after the mission to Iraq. Down there we had to drink 10-15 liters pr day(2.2 gallon to 3.3 gallon) That means you drink continualy through the day.
It got tasteless and difficult to motivate drinking it.
I ended up mixing it with a little gatorade powder to get another taste on it.
But you need to be very carefull with the cleaning of the camelback, when adding things to the water.
Camelback is strongly recomended to all of you guy's.
