Deere500a
08' Peterbilt ISM Cummins for no reason the throttle will cut out, the stop engine light will flash on, for two to ten second then the throttle will come back and the truck runs fine no stored codes and the stop engine lights and alarms stop. Yesterday running up hill empty in the middle lane passing another truck the throttle cut out, coasting up hill you don't get far, the truck on my right backed out and let me hit the shoulder rolling about 15mph. Once the throttle came back there was no issues for the rest of the day. It may do it once it may do it four times then the rest of the week it will be fine it just seems like for that brief space of time it decides to act up. In the past I could turn the key off and back on and everything comes back or flip on the cruise. It's been in the shop twice but with no codes all they are doing is guessing, they replaced the throttle sensor, a new harness is $1100 short of a witch doctor or a voodoo ritual does anyone know what the problem is?
Thank you
Thank you
