Savage
- Joined
- Apr 12, 2009
- Messages
- 47
- Location
- Westlake LA/Balad, Iraq
- Occupation
- Heavy Equipment Operator
Any ideas on why a crane after about 2 hours of running would loose power. We can let it sit for 20 minutes then were good for about 2 more hours. You could heep running it but it just keep getting worse. If you take the load off the motor it revs fine but as soon as you go to do something it just bogs down to the point if you don't stop it will kill the engine. None of the gauges show anything getting hot, also tried changing fuel filter, still no help. Were pretty sure it's some thing electrical getting hot, but haven't pin pointed it.
Just wondering if someone else has had this problem or one similar one and what was the cause.
Thank you
Thank you
