TOM V
Transmission oil cooler hose so far.Nice looking mess, must be one of the belly pans you have dropped. What have you got to do to the crawler?
Thanks for sharing, some of your work, with us.
Yes, you are correct Trbo.Usually just set that particual pan down on my chest and roll out with the creeper. Tried it once with the D6...lil bigger used the jack. That trans cooler line runs the entire lenght down the left hand side correct?
Trbo
Thanks, glad you enjoyed the thread.An awesomely entertaining, thread superb work TomV
CM I dropped the transmission belly pan on a 953B once not expecting it to have as much dirt as it did I damn near broke my arm. The dirt was clear up to the top of the charge pump for the drive pumps.
Thanks Todd, that was a 42" Cat 325 bucket, I had 33 hours into it. I do use the dual shield outside but it does not like the wind.Hey Tom,
Excelent work! How many hours do u have on that bucket? The first one u posted pics of.... Do u usually use the dual shield outside too or do u use a flux core wire?
Thanks
Todd
I have a Gates mobilcrimp 4-20 with the air powered pump and dies 1/4" to 1 1/4".Tom, do you make your own hyd crimp lines? If so do you you use an electric or manual press and what brand? Thanks
No I just installed the body and hoist, I only fabricated the tow plate.Tom did you fab the bed or just install it?
