excavator
On a Dash 5 Hitachi, what can cause the controller to loose its learning? Have a machine that would not shut off with the key switch. Checked it out and found several issues that required the main wiring harness to be replaced. After doing this it took 3 tries to get the learning process to work. The machine was left in the yard for a few days and worked good. It was then hauled about 2 hours away and started having issues soon after. When they start it in the morning it will run a few seconds and shut off. This happens a few times and then it usually runs ok, occasionally they have no throttle control for some time. There are no codes set, but the Dr EX showed the engine learning as "undone". I tried several times to redo the learning procedure and it now shows as "aborted". Running for 5 seconds and then stopping is a symptom of a bad learning switch but I find it hard to believe that would not be a continual problem. When I was there it ran great, started and stopped it approx. 20 times with no issue. The EC sensor voltage and the throttle dial voltage also both check good on the Dr EX. I'm a little stumped on this one.
