PCA16, good advice from Lonestar to test for flooding because if you have too much oil in there, no need to get out the gauges. The only thing we would add is that flooding is caused by one of three things:
-Worn scavenge pump that can’t keep up with normal residual torque oil.
-Excessive oil from torque because of worn seals or cracked impeller.
-Blockage in the system that will not allow oil to return to sump (plugged breather/clogged cooler/rag/etc…).
Keep in mind that the torque is only one part of a system that includes the transmission and brakes and that a metal failure anywhere can damage the scavenge pump and torque causing the symptom but it may be the victim instead of the source.
Which screen did you find the metal in? If you pulled one screen better go for the other one and split your filter too so we can analyze the material and make sure you go for the right component, otherwise you might have to do it all over again.
