first dump truck
Vigilant
Eastern NC
Attitude Adjuster at the Graybar Hotel
Another vote for the KW T800, although I would not turn my nose up at a Pete. Compare the curb weight between the KW and Pete, and the turning radius. They should be close, but some of the competition, especially Mack, falls short in those areas.
Also, if weight is a factor, have a look at the KW T300, or whatever they call it now, and the Pete counterpart. If you will be an owner-operator, either one should hold up well for you. You should be able to easily pick up another thousand pounds of payload.
As for the body, I would be really sure as to what type of dump truck work you want to do. An aluminum body is great for crushed rock, but for hauling stumps and debris, for example, they won't last a good farting spell.
Before you go any further, I would take a good look at the types of dump truck available in your area, what it pays, and how many others will be competing for the work. If you go into this with the wrong truck and body specs, it could cost you dearly. Also, become very familiar with your state's weight laws, and how drop axles could help you, or hurt you.
Good luck to you.
2004F550
Charter Member
Connecticut
Operator/Student
Sounds like a good spec for a tandem shadow, if you have the work for it more power to you since that truck will probably be around 165000 on the road. The Allison is an awesome choice. Before you pull the trigger though I would atleast give KW a shot you might be surprised, I know they don't take well to being out priced by Petes.
Vigilant
Eastern NC
Willis, where are you from? sounds like you may not be too far from me.
Mitch
Rumor has it that Willis does not like it when strangers on the Internet know where he lives. Rumor also has it that he especially doesn't like it when someone who knows him and lives right through the woods from him is posting in this same thread. :D
shadow
ct
i am try to still decided between a 6 and a 10. The mechine that the 6 will tow is a 30000lbs trailer i know the 10 will tow it but will a 6 wheel dump truck
i live in darien ct work for fox hill builders
2004F550
Charter Member
Connecticut
Operator/Student
The six would pull 30k but it would be much more comfortable with the 10 wheeler and the 10 also gives you the higher capacity if you need it.
Willis Bushogin
NC
owner
dump truck
Vigilant, I have no idea what you are talking about, everybody has a opinion
Fattie6SS
Snow Shoe Pa
If you only own one end dump, it should be a KW T-800. If you own more than one, well, most of them should be a T-800. Hendrickson extended leaf only in the rear, unless you get Chalmers. It should have full lockers. Second, it should have a high lift gate, Third, it needs a body vibrator such as Humper Dumper. No more shoveling sticky loads. Don't buy a converted highway truck. You need construction specs for an end dump. Never buy an end dump with air ride. Big mistake! Also, it's better to go broke by charging too much than too little. You're SURE to go broke not charging enough.View attachment 78439View attachment 78439
akroadrunner, just wondering why your against air ride. I drive a Pete bucket with air ride daily, one of the best riding and handling trucks I ever sat in.
akroadrunner
Alaska
Gravel Pit/ Trucking/Owner
EVERY truck I have worked around with air ride has had problems. From blowing a bag, to leaning badly. I know a guy that pulled out to pass in his brand new Pete with air ride. The truck leaned over, and he had to fight it to get back to the right lane. He pulled the dump box off, and put on a fifth wheel. I've seen them with loose loads (wet muck) take a corner and look like they were going to fall over. If they are loaded a little heavy on one side they go down the road with that 'gangsta lean'. Just lower the air seat all the way, rest your arm on the door, and put your hat on sideways. Maybe you drive around empty a lot 'down there'. We are often hauling grubbing out (that's where the high lift and vibrator come in handy) and gravel back in. Loaded both ways. We are not hauling down a freeway either. Rural roads, many of them gravel Borough roads. The asphalt roads are rutted badly from 6 months every years of studded tire abuse. Plus we can gross higher here than many places in the lower 48. With my floats on the steer axle, 246" wheel base, and no lift axle, I gross 55,000.
shadow
ct
i the state of ct to have a gcvw of 80000lbs what lenth dose the wheel base need to be if you have 6 axles. 3 on the truck and a triaxle trailer
shadow
ct
i have gone with a 6 wheel dump truck and i tring to fugure out the rite side hight and tail gate hight to hold 10 tons of rock and tap rock or mud with out being overly big
i have the truck spec with a 30in side with a 8in board and a 42in tail gate
55,000 lb trailer, are we talking about a tag along trailer? They probrably make them, but Ive never heard of a tag along that big. I have never seen a tandem dump truck, pulling that kind of load. That would take a big pintle hitch and a real good welder to make the hitch.
Willis, I have a 55K Betterbuilt tag trailer. It has two 22.5K axles although I am limited to 20K per axle plus any tongue weight. I have pulled it with a tri-axle and a tandem hauling a 953 D6n and 315, the tri was better just because you could lower the lift axle to smooth the ride out and add an extra set of brakes.
Several manufacturers make them. There are tri-axle 60K tags as well.
This is one like I have - http://www.betterbuilttrailers.com/22 5k dual tandem pintle hitch.htm
Some others -
http://www.eagerbeavertrailers.com/easy.html?mute=off
Here's a 60K tag -
http://www.xlspecializedtrailer.com/item.asp?catID=tag&ID=26
shadow
ct
we just purchase a kenworth t370 six wheel dump truck
Alison auto transmission
350 hp paccar engine
10 ft bibeua bbfl smooth sided body
30 in side and a 42in barn door tail gate
35 ton pintail hook
10k front 23k rears
Wow! $106 large for a single axle?:confused: You may have already stated but what kind of work do you guys do that a single axle will not only foot the bill but make a profit at that price?
auto transmission
35 ton pintail hook
10k front 23k rears
Nice specs, can't wait to see the finished product. Make sure you order the tractor package to pull an air brake trailer and an engine brake.;)
shadow
ct
We spend about 6000- 10000 dollars a month on moving machines and having material delivered. dirt moved from on job to anther.
we own 3 excavators 3 bobcat loaders and 2 small dump trucks
we also trying to become more legal
the truck has a two stage jake brake and air and electric brakes to the back of the truck
Haddy
Atiamuri New Zealand
earthmoving contractor
3306
They're extremely reliable, I have the CAT 3306 oddball turned up to 400HP its very strong and runs good.
Hi JDM . Would like know what was involved in getting your 3306 up to 400 HP . I quess it would shorten the life of the motor , maybe . I got one in my KW and a few more HP would be nice . Haddy
shadow
ct
