HELP! Looking for Caterpillars Spec/fact sheet for any of the 5110 series Excavators
BigIron25
Missouri
Hello gents, I have been looking for Caterpillars spec sheets/fact sheets for their 5110 line of excavators. I cant find anything on their website pertaining to this machine. Maybe im looking in the wrong place? Maybe this is a special request I have to put in through caterpillar? Im sure alot of you know better than me, any help will be greatly appreciated. thank you.
dist3
Connecticut
Equipment Manager Enviromental and Site Contractor
5110B Mass Excavator
Specifications
Specifications
Units: US | Metric
Units: US | Metric
Engine
Engine Model3412E HEUI™
Net Power519 kW
696 hp
Gross Power565 kW
758 hp
Bore137 mm
5.4 in
Net Power-EEC 80/1269519 kW
696 hp
Displacement27 L
1649 in3
Net Power-Caterpillar519 kW
696 hp
Net Power-ISO 9249519 kW
696 hp
Net Power-SAE J1349514 kW
689 hp
Stroke152 mm
6 inHydraulic System - Implement/Travel
Main Implement - CircuitClosed center load sensing
Main Implement - PumpPiston, variable
Max Flow at 1915 rpm (1x)463 L/min
123 gal/min
Relief Valve Setting - Travel35000 kPa
5075 psi
Number of Implement/Travel Pumps3
Relief Valve Setting - Implement - Std.32000 kPa
4640 psi
Max Flow at 1800 rpm (2x)437 L/min
115 gal/minHydraulic System - Swing
Swing System - CircuitOpen center load sensing
Swing System - PumpPiston, variable
Number of Swing Pumps1
Relief Valve Setting - Accelerating35000 kPa
5075 psi
Relief Valve Setting - Decelerating25000 kPa
3625 psi
Max Pump Flow at 1915 rpm463 L/min
123 gal/minHydraulic System - Pilot
Pilot System - CircuitOpen center
Pilot System - PumpGear
Number of Pilot Pumps1
Relief Valve Setting - Controls4500 kPa
650 psi
Relief Valve Setting - Track Tension7000 kPa
1015 psi
Max Pump Flow at 1915 rpm59 L/min
15.6 gal/minHydraulic System - Cylinders
Boom Cylinder - Bore235 mm
9.25 in
Boom Cylinder - Stroke2540 mm
100 in
Bucket Cylinder - Stroke1800 mm
70.9 in
Stick Cylinder - Stroke2330 mm
91.7 in
Bucket Cylinder - Bore254 mm
10 in
Stick Cylinder - Bore254 mm
10 inOperating Specifications
Stick Length - Standard3.4 m
11.2 ft
Target Payload - Long11200 kg
24700 lb
Maximum Reach at Ground Level13.5 m
44.2 ft
Maximum Dump Height8.6 m
28 ft
Bucket Capacity - Heavy Duty Rock7.6 m3
9.9 yd3
Bucket Breakout Force (SAE)501 kN
112600 lb
Stick Breakout Force (SAE)439 kN
98800 lb
Bucket Breakout Force (ISO)586 kN
131700 lb
Stick Breakout Force (ISO)458 kN
103000 lb
Truck Payload Match55 tonnes
60 tons
Boom Length - Standard7.6 m
24.9 ft
Cat Truck Match773D, 777D
Operating Weight - Std.125000 kg
275000 lb
Target Payload - Std.13700 kg
30200 lb
Maximum Digging Depth7.9 m
25.9 ftDrive System
Maximum Travel Speed - Low2.5 km/h
1.6 mph
Maximum Drawbar Pull846 kN
190350 lb
Maximum Travel Speed - High3.3 km/h
2.1 mphSwing Mechanism
Swing Speed4.6 RPM
4.6 RPM
Swing Torque473 kN·m
349000 lb ftUndercarriage
Track Width - Rock700 mm
28 in
Track Width - General Purpose900 mm
36 in
Track Width - Soft Underfoot1000 mm
39 in
Ground Pressure - Rock147 kPa
21.4 psi
Ground Pressure - General Purpose116 kPa
16.8 psi
Carrier Idlers3
Track TensioningAutomatic
Shoes Per Side - Std.55
Rollers Per Side - Std.9
Ground Pressure - Soft Underfoot105 kPa
15.2 psiService Refill Capacities
Fuel Tank1700 L
450 gal
Cooling System113 L
30 gal
Engine Oil83 L
22 gal
Hydraulic Tank891 L
235 gal
Final Drive (each)22 L
5.8 gal
Hydraulic System (incl. tank)1687 L
445 gal
Swing Drive9 L
2.4 galStandards
Brakes - SwingISO/DIS 13677
Brakes - TravelISO 10265
Cab VibrationEC 89/392EECDimensions
Overall Width5460 mm
17.9 ft
Upper Structure Width3500 mm
11.5 ft
Ground Clearance1052 mm
3.5 in
Overall Height4806 mm
15.8 ft
Counterweight Clearance1890 mm
6.2 ft
Counterweight Height2410 mm
7.9 ft
Cab Width993 mm
3.25 ft
Width to Outside of Tracks4800 mm
15.75 ft
Track Gauge Width4100 mm
13.4 ft
Track Length - Std.6864 mm
22.5 ft
Track Length on Ground - Std.5452 mm
17.9 ft
Overall Length - Std.8552 mm
28.1 ft
Height to Top of Cab4615 mm
15.1 ft
Height to Top of Counterweight4300 mm
14.1 ft
Tail Swing Radius5120 mm
16.8 ft
Find a Used Excavator
Visit CatUsed.com™ to find used equipment from your dealer.
» Go to Web Site
Mobile Facebook Twitter YouTube Newsfeeds© 2011 Caterpillar All Rights ReservedLegal NoticesSite MapPrint VersionContact
BigIron25
Missouri
Thanks dist3 exactly what I was looking for, I appreciate that. Where did you find that at?
dist3
Connecticut
BigIron25, www.cat.com under products and then non current machines. If you have a local salesperson ask them for or look thru Cat performance handbook. Have a good day
BigIron25
Missouri
Thank you sir, I didnt think to look under non-current machines because most look brand new. I appreciate the guidance!
D11RCD
COPPA Member
Diesel Mechanic
Just so you know, Terex took over the 5000 series line from Cat, turning them into some of the RH excavators. Just a heads up, correct me if I am wrong.
alco
here
Terex did not take over any machines from Cat's 5000 series. There was a deal in the works at one time, but it was never completed.
