Hey I'm new to the forum and looking for some advice. A guy wants me to do a bid for moving his septic lift station under slab to a new manhole just outside the house. Not sure how to bid this project because it seems there are too many unknowns. Also it is very tight, only 20' to other duplex with property line at only 10'. Doesn't look like any utilities to dig around. The other problem is that to get to the pipe in the tank in the house I will have to dig below the bottom of foundation by a couple of feet which this house has the prefab walls bolted together on the corners and sitting on 3-4' of 3/4 washed rock. So i'm afraid of undermining a bunch of that wall and slab. Any thoughts? Also I'm trying to do this with the smallest hoe I can with being able to still set that manhole base safely, roughly 6600lbs. What size of hoe?
Thanks for any help
Thanks for any help
