So I'm messing with another old machine and again looking into a possible hydraulic issue. At idle and low speed there is a thumping noise that you can hear/feel. I traced it back to one of the pressure lines coming off of the tandem pump (similar set up to the pump i posted pics of a few weeks back.) I was told this pump was fairly new.. could this thumping be air thats being compressed in the pump? The pump is a tandem and the thump can only be felt on one outlet, if the pump was drawing air i would think you'd feel it on both..? What else could this be? it goes away once you throttle up.. I think the pump is a vickers again.. any thoughts?
