Help with a Bomag BW211d-3
bean
Anyone have a parts manual for a bomag211d-3. There is a small cartridge broken on the vibration hydraulic pump with no part number on it :(. There is no manual as it was purchased used.
eric12
new york
call your local dealer, they should fax you a few pages with what they think your looking for. theyre out to make money and they cant sell you parts without you knowing what you need.
bean
located the needed parts via my hydraulics dealer once I figured out which model of rexroth pump I had
goran
quito
help with bw211d-3
Good morning,
I have the same problem with our Roller. There is no Rexroth tag on vibration pump. have Bomag pn but it will cost a fortune to buy new pump using that. I would apreciatte it a lot Bean if you can help me with Rexroth pn you have. my mail is budzovan@gmail.com . Thank you very much , goran
goran
quito
Good morning,
bean
The pump was a Rexroth A4V. I had to replace the Solenoid asy (coil/armature tube)
It was about 80 bux and a week delivery. The entire control for the pump is about 1k.
goran
quito
Vibration pump Bomag
Thank you. I was given this code A4VG56DA1DT3/32RPZC02F025S but i can not be shore about it and i would like to confirm it. the thing is we have bought the roller that was udsed before.Someone addapted Sauer Sundstrand pump that should not originally be there( was a quick solution for a 80 week problem i suppose:)) and does not work perfectly. Now i want to get originall as ,Sauer unit should be repared,but i am in problems to get the right pn. I have a manual, it should be this A4VG56 or smaller but there are so many option about the control and i do not want to risk buying it before i get pn right.I would apreciate you so much if you can check it and give to me, it would be a great relief. Best regards;
Goran
bean
Sorry but thats all I know. I took a picture of my pump and sent it to my hydraulic repair depot and they came up with the A4V and parts.
Only other number I have is Ident-NR 2052703 Sach-NR 05800928 FabrNR 6468381 which I am sure you have aswell.
goran
quito
If you still have a photos of the pump it would mean a lot if you can send me? I belive i can use that .my mail is budzovan@gmail.com. Please help me if you can.
goran
quito
It would mean a world to me if you can send me this photos. I have the photo of the unit i was offered and due to your photos i can compare it to be shore. I would apreciate it a lot.Goran
goran
quito
photos
Hello once again,sorry to bother you, but...as it knows to happen i am desperate with this construction equipment.I have a friend who can decode the pump to rexroth but he needs more information, the old pump or the photos...i do not know who can help me other than you. We can share this exact part number,i will pass it to you if you help me with a photos and that will easy all your problems if you will need parts in the duture. Please help me if you can,best regards,Goran.
