I got a Lift A Load gooseneck trailer model # EPG4-314. It has a payload capacity of 7500 lbs and 4 wheels with each wheel rated at 3000 lbs . Trailer weighs about 4100 lbs empty.
http://www.lift-a-load.com/goose.html
Even though the below PDF mentions each " axle " as being rated at 6000 lbs, since the wheels aren't connected by a common axle , I refer to them as wheels instead.
http://www.lift-a-load.com/Lift-a-Load_EPG4-314.pdf
The trailer rises and lowers hydraulically to ground level or loading dock height.
Ok so here is my concern.
The underside of the trailer deck and cross members has corrosion all over. There are rust flakes that can be broken off from the cross members. The corrosion does not go all the way through the cross members but the thickness of the cross members is noticeably reduced . The width/depth and length appear intact .
So should this be of concern? Has the payload capacity been reduced?
The trailer isn't with me right now or else I would post a picture.
I got a lathe that weights 8500 lbs, would it be alright to move it a short distance, like 20 miles with this trailer?
If you look at the specs for the next size up trailer the EPG-514, the payload capacity is 10000 lbs and the only difference between mine and it is that the frame depth is 4" on mine and 5" on the 10,000 capacity one. Both have the same 6000lb 'axles'.
http://www.lift-a-load.com/Lift-a-Load_EPG4-514.pdf
So if I got a welding/fabrication shop to weld in additional cross members of 5 " width/depth parallel to the existing ones, could I then haul 10K lbs?
