Tony_F
Some of you may have seen the thread on the failure of the final drive on my KX91-3....https://www.heavyequipmentforums.com/showthread.php?21644-Kx91
Below is another picture of the parts with a ruler and pen for size comparisons. The parts are aligned how the are assembled in the drive - the male end of the gear drive goes into the female end of the shaft. The worn male splines are clearly visible, the female splines look the same. The splines wore out at 1765 hours. The other side failed at 1400 hours (but I did not have to replace that one, it was done before I bought the machine, I also don't know exactly what parts failed in the drive unit, I was just told it was replaced) The rest of the gears and bearings in the failed drive look fine - no visible wear on most of them.
The shafts are tiny, just under a 1/2 in diameter. I understand the final drive gears are a torque multiplier, but still its hard to believe that the entire motive force starts with these small shafts.
These parts are in the deep center of the drive unit and in my guess receive very little direct lubrication. My guess is the design and gear oil played a factor here? Comments?
I've switched from the Kubota 85W-90 gear oil to AMSOIL SEVERE GEAR® Synthetic Extreme Pressure (EP) Lubricant 75W-140 hoping the full synthetic oil would provide better cushioning.
Tony
Tony
